W-6 woes
kirk in ks,
08-13-2007 06:49:38
I was taking to this mechanic,about this W-6, and he said on the hyd lines, just block the pump off at the mount and run it that way,
No Big thing,
Janicholson
08-13-2007 07:37:23
 Re: W-6 woes in reply to kirk in ks,, 08-13-2007 06:49:38
We do not know what you mean, by blocking off. If it is a live pump, it cmust have fluid in it to survive. (a loop of hose, and filled with hytran from intput to pressure ports) If it is a belly pump, it can be removed with no harm to anything. Tell us more. JimN
kirk in ks,
08-13-2007 08:07:15
 Re: W-6 woes in reply to Janicholson, 08-13-2007 07:37:23
Hi Jim
It's kirk,
I just realized that i cant do that cause the pump is connected to the distributor, and it has to have a base on which to move, so that's out,
I guess when the weather gets better not soo muggy ill dive into it and redo it and then itll be ready to drive,
kirk,
