1486 IH
Delilah
08-01-2007 17:22:58
Installed new ta tractor moves fine ta does nothing when you move handle. Any suggestions?
the tractor vet
08-01-2007 19:30:32
 Re: 1486 IH in reply to Delilah, 08-01-2007 17:22:58
Don't know as i did not do the job , are you sure that ya got all the O/rings installed on the tubes and did not cut one while you were pushen them in . DId you have the MCV apart ?? Did ya get the end clearance set correctly , Is the seletor valve working and set correctly ??? Did the cable come off ??? With out me being there there are a lot of did ya do this or that. Did ya check pressures and did ya install a new MCv pump???? Sometimes this falls under the heading that don't try this at home let the trained perfessionals do it .
