Rebuilding a 123 ci, question on cyl kits
scott#2
07-26-2007 17:02:22
Im about to start on a 140 engine rebuild for a friend. The cylinder/piston kit he got from the machine shop has different style pistons than what came out. They are Red Power part # RP374338R93 and have 2 raised square domes on the tops. Are these hi perf pistons? Or are they a updated stock replacement piston? Any problems with deck/valve clearance here? Just curious, I was looking for a stock rebuild without a bunch of measuring, clearence mods, etc. Looks like the head was milled as well maybe .010 or so. Any help is appreciated
Thanks,
scott#2
BIG RED 1
07-27-2007 09:20:20
 Re: Rebuilding a 123 ci, question on cyl kits in reply to scott#2, 07-26-2007 17:02:22
I just completed what your starting on my 140,using the exact same part.
The pistons you have are the aftermarket accepted replacement.Im told the original flat tops are still available,however whats wrong with a couple of more horsepower.
For piece of mind you may want to set your head on,start the headbolts,and cycle slowly with a hand crank,slowly drawing your headbolts tight to torque spec,set valves,and cycle with hand crank-I know alot of jim-jackin around but will let you sleep until you are ready to run it
have fun
RANDY
EL Toro
07-27-2007 05:16:41
Once you have the head on and the valves adjusted I would hand crank the engine one complete revolution to make sure valves and pistons clear one another. Hal
gene bender
07-26-2007 19:14:53
Everything should be O.K. There are different types of hi-domes out there but they all work.
S/C Bob
07-26-2007 18:35:25
I have a complete rebuild kit I bought for my tractor but I found an engine so I don`t need it. If interested you can call 423-239-3790 Thanks and good luck..... Bobby
