F-20 Rod bearings
Greg NE
07-21-2007 15:59:55
Do any of you know if there is a source for new rod bearings for a F-20? I have a friend that is going through one and he has a bad bearing but at least the crank is still smooth. Thanks in advance Greg NE
El Toro
07-21-2007 17:16:53
 Re: F-20 Rod bearings in reply to Greg NE, 07-21-2007 15:59:55
You can try the thefordsonhouse in MI. You should have the rod journal measured to see if the
journal has been ground undersize. Rice Equipment may have some parts too. Their number is 814-327-9200. Hal
Greg NE
07-22-2007 08:03:17
 Re: F-20 Rod bearings in reply to El Toro, 07-21-2007 17:16:53
Thanks, I've dealt with Rice before and had good luck, didn't think to give them a call (brainfade) and I'll check on the Fordson House. thanks again Greg NE
El Toro
11-03-2007 07:22:05
 Re: F-20 Rod bearings in reply to Greg NE, 07-22-2007 08:03:17
HI Greg, Do you have the torque spec for the F20 rods and the valve lash setting? Hal
