Tie Rod or Welded Cyl. for my Loader??
Wayne Rimathe
07-08-2007 09:34:08
I need to replace the welded single 18 inch stroke dump cylinder on my Koyker loader on my 656. Would a tie rod replacement cyl. with the same stroke be just as good? Both kinds are available. Which should I buy and why?
Janicholson
07-08-2007 18:51:52
 Re: Tie Rod or Welded Cyl. for my Loader?? in reply to Wayne Rimathe, 07-08-2007 09:34:08
If the Ram is the same diameter, and the cylinder is pressure rated the same or better, I would go with the least expensive. I have used tierod cylinders often. JimN
Brownie450
07-08-2007 15:08:41
Don't know as it would matter which you use, as long as the cylinders are rated for the pressure which is being developed.
