300U hydraulic controls
rbachy
07-03-2007 07:03:20
I recently got a 300 utility, everything seems good except the hydraulic controls are all backwards (down is up - up is down) I was able to switch the hitch controls by simply reversing the hoses into the cylinder. BUT the loader isn't letting me off that easy. These are Single action cylinders and setting is correct. One posting I read said something about the T to the loader going on the right cylinder. Mine is on the left. Would that do it? Thanks all!
John-Paul T
07-03-2007 11:55:31
 Re: 300U hydraulic controls in reply to rbachy, 07-03-2007 07:03:20
Are you sure the loader isnt just like that? We recently got a IH 2500 and it is like that. In our case Im certain it should be since it still has factory stickers on it! It shows up on lever is down on bucket. One more up is float. Down on lever is lift. In fact the new hydro's we rented are same way. Just with a 4 way single valve control instead of 2 seperate ones.
