Governor bearings
Doug Coutts
06-28-2007 11:55:07
Rebuilding governor on my SC. Read all the posts - very helpful. Stupid question - do I grab the old bearings/bushings and yank them out, or is there a kinder/gentler way. Same question would apply to PTO, etc. Thanks.
gene bender
06-28-2007 19:45:59
 Re: Governor bearings in reply to Doug Coutts, 06-28-2007 11:55:07
Dont forget to rebush the in-put shaft and a new gov spring
Janicholson
06-28-2007 14:24:46
A bearing driver is what is best. I ulook at all of my sockets first to see if any are just right to push on the perimeter of the bushing. If so there it is. If not, they need to fit just under the bore size or the bearing will get crooked in the bore and be more difficult, and you need the driver to install the new bearing anyway. Making one out of bar stock, or schedule 40 pipe with a welded in plug to pound on is OK. Machining one is easy with a lathe. Or buying a driver from a tool store. JimN
