450 t/a
Hoss357
06-26-2007 08:46:44
do they make such a thing as a t/a eliminator??
Kevin Meier
06-26-2007 15:26:48
 Re: 450 t/a in reply to Hoss357, 06-26-2007 08:46:44
Yes they do have a t/a elimination for a 450. I have them in stock as well as the t/a. Drop me an email if you are interested.
Hoss357
06-26-2007 09:43:53
the t/a clutch slips the tractor has no t/a handle to engage or disengage tried adjusting linkage and clutch???? engine clutch they said was new when i bought the tractor this winter?
georgeky
06-26-2007 09:51:35
 Re: 450 t/a in reply to Hoss357, 06-26-2007 09:43:53
If it has no handle it may have the elinination kit in it already. These are usually removed when the kit is put in. My 450 slipped to when I first got it to running. I cured it with a linkage adjustment. Is the linkage for the handle missing as well?
Hoss357
06-26-2007 10:26:10
 Re: 450 t/a in reply to georgeky, 06-26-2007 09:51:35
no the linkage that hooks in w/the engine clutch is there. there is a clutch in the t/a would that be there if the t/a was eliminated? the engine clutch doesn't slip the t/a clutch does???? it's not that i don't want to fix it i didn't know wich way would be cheaper and easier?any hints or things to check or adjust????? ?
georgeky
06-26-2007 11:28:42
 Re: 450 t/a in reply to Hoss357, 06-26-2007 10:26:10
The TA can not be adjusted without that handle. It will not work without that handle. So I sussest you get a handle. I may have one. I will look to see. Email me if you are interested in one. I don't know how much the elimination kit cost, but TA's are a little high. I would do as the vet suggested and see about one of the newer style TA's. I assume it will be the same amount of trouble for each one. However there may not be much wrong with what you have. Are you sure the clutch is slipping or the roller and ramp set up in the unit? Parts are available for them and with the book, you can fix it yourself. They are not as bad as some think. But if you keep the TA you will need that handle.
the tractor vet
06-26-2007 09:41:34
If you are going thru the trouble of spliting the tractor and for a few more buck ya can fix it wright and keep the T/A and have something that means more on the resale of the tractor . And with the new spragless T/A's of today this is a no brainer .
Kevin Meier
06-26-2007 15:29:37
 Re: 450 t/a in reply to the tractor vet, 06-26-2007 09:41:34
I rebuild the mechanical and hydraullic t/a's and have never heard of a spragless mechanical t/a. If you have any more info about the spragless mechanical t/a, please send me an email or reply. Thanks
georgeky
06-26-2007 09:44:36
Vet, that is exactly my opinion on the matter. Why not just fix the TA. Seems like about the same trouble to me. Then again I ain't to bright.
georgeky
06-26-2007 09:33:47
Yes there is a TA elimination kit. I have a 450 that has one in it. I also have a 400 that has a bad TA in it and I just use it in direct drive and it works fine. I really don't know why you would need the eliminator.
the Unforgiven
06-26-2007 09:29:09
Yes they do, try SteelWheelRanch.
