Thermostat ( 1256)
Eddie Jones
02-12-2007 19:06:37
I have freind that had a 1256, when you run it for awhile it blow water out the around radiator cap. Does it have a thermostat that could be causing it to do that. Or could it be a headgasket. No water is getting in the oil. If it the thermostst where would it be?
Thanks in advanced, Eddie
Don L C
02-13-2007 03:52:06
 Re: Thermostat ( 1256) in reply to Eddie Jones, 02-12-2007 19:06:37
...Take the thermostat out and put the housing back on.....run for a while and see if problem goes away..... if it goese away, get a new thermostat.....fill with 1/2 water,1/2 antifreeze.....sounds like it might be a good time to replace the cap.....
Allan In NE
02-13-2007 03:46:07
Check the simple things first.
Like all IH tractors, ya can't "overfill" 'em; they'll just blow it right back out first time you put a good load to 'em.
Also, is the cap okay?
Allan
K.B.-826
02-12-2007 19:46:30
Most likely the head gasket but I have seen a stuck thermostat do that once. Thermostat is in the thermostat housing, which is located on the engine end of the upper radiator hose.
