Rebuilding an IH remote control valve??
John in Ct
02-06-2007 13:46:42
I just got a Remote Control Valve and now want to rebuild it(The valve that lets you use a 2 way hyd. cylinder) to use on my Farmall H. Is there a repair manual available? I have the one for the Lift-All. If not, how do you adjust the 2 nuts on the spool?. Also, I don't have a control rod for it yet, where the control rod would go is oval. I want to make a bushing like I did for my Lift-All, is the control rod the same diameter as the Lift-All control rod. Thanks!!
