Farmall A Water Drain Plug
CT-Farmall
02-04-2007 19:54:15
Looking for information on the cooling system drain plug located on the front left side of the tractor. I thought it was an 1/2" NPT Pipe plug but was wrong. There was a 5/8-11 bolt stuck in there when I got the tractor. Looks like it is part number 45314 DC.
Does anyone know if this is truly a UN stlye thread or is it a special.
Where can I find this plug?
Thanks,
Tim
Roger Mills
02-05-2007 07:36:25
 Re: Farmall A Water Drain Plug in reply to CT-Farmall, 02-04-2007 19:54:15
The plug on my A (44') is winged with a distinct taper and very thin (shallow rounded) threads. I think it is original and is a wedge fit. I saw them on OEM or here. Mine leaked antifreeze and I wrapped it with teflon tape-fine now. The IA (47') is tapped to NPT and has a 4" nipple with a standard pipe cap.
Vacherie
02-04-2007 20:31:12
I replaced a bolt in my Super A. I remember using a 3/8" nipple and 3/8" valve. But it has been several years ago.
