IH 460, looking for loader
jeff91
02-02-2007 13:11:41
would anyone know if an IH 2250 loader would fit on a IH 460 tractor. thanks for any input.
K.B.-826
02-02-2007 16:43:31
 Re: IH 460, looking for loader in reply to jeff91, 02-02-2007 13:11:41
Yes, if you have the correct mounting brackets. The brackets vary from tractor to tractor, quite a few different ones. Brackets for a 06, 26, or 56 series tractor may bolt right up to a 460, and I know they will work with some slight modification. I think the ones for the 74/84 series utility tractors would be real hard to make work, so stay away from those. Unfortunatly, those were the most common. I can give you some tips on making the 06, 26, 56 brackets fit if you need help.
jeff91
02-06-2007 06:47:06
 Re: IH 460, looking for loader in reply to K.B.-826, 02-02-2007 16:43:31
thanks for the help, i have some brackets so i'll see how it goes.
