350 Clutch Shaft Needed?
Short Bolt
01-29-2007 05:08:08
I have a farmall 350 that came out of factory with out a TA. While pulling it hard cleaning trees out of the fence row. It with pop and quit pulling. Thought it was the clutch. When we split it! the shaft that goes from clutch to the trans broke off and broke the trans input teeth off. Any one have the parts?
Nat 2
01-29-2007 05:32:22
 Re: 350 Clutch Shaft Needed? in reply to Short Bolt, 01-29-2007 05:08:08
Have you tried your local CaseIH dealer? They may still be able to get the shaft.
How about local tractor salvage yards? Try Steel Wheel Ranch too. This part is small enough that most yards will ship it to you if they have it.
