Order Farmall Cub Parts Online
Farmall Cub Shifting forks
Glen Davis
02-06-2000 08:13:54
I have a cub with broken shifting forks in the transmission. I have been told by one source that I can replace these without removing the transmission. I have read in the manual that I need to remove the transmission. Can anybody help me with this? I need to get the ractor up and running again. Thanks
Jim Becker
02-06-2000 19:36:01
 Re: Farmall Cub Shifting forks in reply to Glen Davis, 02-06-2000 08:13:54
Unbolt the fork from the rail. Hold a finger over the hole where the rail detent is so the ball isn't lost. Slide the rail back until the fork is free. When reversing the process, use a long nose punch to hold the detent ball down while the rail is slid over it.
Justin
02-07-2000 10:36:28
 Re: Re: Farmall Cub Shifting forks in reply to Jim Becker, 02-06-2000 19:36:01
I did the samething as you did. The job was easy to.
