Farmall B head gasket guestion
Dave U
01-22-2007 07:03:20
third party image
First, thanks to those of you who posted responses to my questions. My Farmall B is back together and hauled wood this weekend. I posting a picture showing what was wrong. I got this tractor this spring. It ran good but always had a clicking nose coming from the governor. I found the problem was a broken tooth on the cam gear.
A month ago there was a loud snap and the engine started to run hot. I parked it in the garage and started to trouble shoot. I needed to put in rings any way. Number two cylinder was pushing oil.. There was a broken oil ring. When the engine was dissembled I was surprised to find that everything measured near new specs. I put in new rings and connecting rod bearings. My IH dealer had a good used cam with gear and governor gear. Put it all back together and it started in the first try.. There is a short video of the results.
Keith-OR
01-22-2007 20:54:42
 Picture of Cam gears in reply to Dave U, 01-22-2007 07:03:20
Hope this is the one you tried to post.
Keith & Shawn
third party image
JayWalt
01-22-2007 11:54:13
 Re: Farmall B head gasket guestion in reply to Dave U, 01-22-2007 07:03:20
pic doesnt work, neither does the video =(
Hope you can fix it, i wanna check it out =)
