1086 Hydraulic lift
Randy Perkins
01-19-2007 17:43:19
I have a 1086 that the lift just stopped working. We checked the relief valve and unloader valves. Any suggestions
the tractor vet
01-19-2007 17:58:24
 Re: 1086 Hydraulic lift in reply to Randy Perkins, 01-19-2007 17:43:19
What system does it have the old style open center or the PFC ????? If it the old style then remove the top link plate and get a trouble lite and look inside on the right you will see a arm (lever) comming up from the bottom and a arm (lever) hanging down from the top . the one on top has to be on the back side of the one from the bottom , it is wise to use a hook to pull the top one back and hook it over the other one as there will be heavy spring resistance and there maybe some real sharp edges . Now if it is a later model 1086 then it will have the PFC system and here it could be a 100 differant things so if that is the case then your at the dealer's mercey .
Allan In NE
01-19-2007 17:46:54
Do your remotes still work?
Allan
MACKY
01-19-2007 17:59:57
 Re: 1086 Hydraulic lift in reply to Allan In NE, 01-19-2007 17:46:54
KEY SHEARED ON THE HITCH PUMP. HITCH PUMP SHOT. O-RING BLOWN ON THE HITCH PUMP. THE HITCH PUMP IS LOCATED IN FRONT OF THE LEFT REAR AXLE AT THE BOTTEM OF THE REAR END HOUSING.
