856 tilt steering help
pt756
01-05-2007 18:44:02
have bought new universal joint for steering, now the support is worn a little, can it just be re-bushed and bored to correct size or can a bearing be put in part is over 150 dollars thank you
the tractor vet
01-05-2007 19:14:37
 Re: 856 tilt steering help in reply to pt756, 01-05-2007 18:44:02
Well i use to have a machine shop make up the stuff i needed and it worked well and it was only around 60 bucks but i was lucky that the machinest worked cheap
