H Farmall part
Thumbanger
12-31-2006 15:17:50
Need bracket that bolts under hydrolic lever arm that choke and belt pulley rod goes throuhg for H have watched e-bay and checked other sources any help. Thanks
andy swaim
01-01-2007 10:59:45
 Re: H Farmall part in reply to Thumbanger, 12-31-2006 15:17:50
i have one, and i'm parting out the H its on. how does $15 plus postage sound? the serial# is FBH261317 Call or E-mail 765 569 6007
farmallhal
12-31-2006 20:35:19
As shown in my H parts catalog the part is called a control bracket. It is reference no. 22 in my TC-27E parts catalog. The part no's. are 60837DB for s/n's 70410 through 391357 and 358202R1 for s/n 391358 and up. No mention of what was used prior to s/n 70410. Hope this helps, Hal.
John M
12-31-2006 19:43:10
You mean the rear gas tank support.
Thumbanger
12-31-2006 18:14:26
Its bracket below light switch and amp gauge box your choke rod and belt pulley rod goes through
Tom Windsor
12-31-2006 17:57:11
Most likely have it but from your description I don't know what you are asking for. ???
Bob V
12-31-2006 16:27:28
I might have it, but I am in NY. You might want to get it locally. Where are you located?
kfox
01-01-2007 00:32:47
 Re: H Farmall part in reply to Bob V, 12-31-2006 16:27:28
This bracket also holds the radiator shutter control crank. I think I've read that the very early models had the shutter crank mounted on the rear gas tank support. Must be the ones before 70410. ken
