Regular valve lifter/rocker arm
James Autry
12-18-2006 15:33:24
Does anyone know what the ordering of rocker arms are?? In the parts book, they are listed as front and back (49/50). Does this mean the 49s makup the front set of 4 and the 50s the back? ie. which are intake and exhaust?? Also, how far is the rod expected to travel in order to tell if the cam is too worn?? Thanks
James Autry
12-19-2006 18:32:34
 Re: Regular valve lifter/rocker arm in reply to James Autry, 12-18-2006 15:33:24
Thanks for the replies, just that I cannot seem to adjust them ie. there is not enough lever screw length to get .015. Just want to make sure whomever overhauled this thing got it back together right. Thanks.
thurteauf14
12-19-2006 15:12:03
Hi James Looking in my service manual for the farmall f-20 pritty much the same engine as the farmall regular they say that the valve lift sould be as follows the (intake.266) and the (exaust.298) and the tappet gap of .015h (hot)they don't give a range but i think these engines are pritty forgiving with tolorences,as for the valve rocker arm i will look at my regular and check the order and get back to you. Tom
russ hamm
12-19-2006 08:21:14
james, i have always kept them in the order they came off so i'm afraid i'm not much help. i can tell you that cam wear is something iv'e never checked and i know those old girls will run well even when redone by a shadetree such as myself. good question though. maybe someone else?
