506 Diesel weight
Lance R.
12-18-2006 14:18:56
I've seen some posts in the past about how much a 560 Diesel weighs. My 560 Diesel has a fast hitch, a heavy duty 806 type IH wide front, a front end suitcase bracket, and new Firestone 15.5 x 38 radial rear tires. I weighed it this past weekend at a certified scale with full fuel and it weighed exactly 7000 lbs without the driver. I'm getting the TA and clutch replaced between Christmas and New Years.
Hugh MacKay
12-18-2006 15:24:13
 Re: 506 Diesel weight in reply to Lance R., 12-18-2006 14:18:56
Lance: 806 front axle wouldn't change anything as 560 and 806 used the same front end.
RustyFarmall
12-18-2006 14:43:06
I assume that there were no suitcase weights, just the bracket? And no rear wheel weights or fluid?
Lance R.
12-18-2006 19:25:12
 Re: 506 Diesel weight in reply to RustyFarmall, 12-18-2006 14:43:06
And no fluid.
Lance R.
12-18-2006 19:22:28
That's correct. There were no rear wheel weights and no suitcase weights.
RustyFarmall
12-18-2006 21:36:28
 Re: 506 Diesel weight in reply to Lance R., 12-18-2006 19:22:28
Thank you. It's good to know things like that before you get ready to load it up on a trailer.
