H Experts; Need Your Expertise
City-Boy McCoy
12-17-2006 01:13:47
Howdy, Boys:
You know how a late 1950 M, and newer, had the heavier duty timing gear and newer style front engine cover (like a Super M) so you can easily add a live hydrulic pump with all assurances it will last?
Well, when did the H get that same similar change/update? Or did it not happen until the stage one super H? Is there a way to visually recognize/identify the newer style on an H without disassembly?
Thanks. mike
City-Boy McCoy
12-17-2006 15:45:31
 Thanks, Guys!!!! in reply to City-Boy McCoy, 12-17-2006 01:13:47
mike
chuck46
12-17-2006 15:32:53
 Re: H Experts; Need Your Expertise in reply to City-Boy McCoy, 12-17-2006 01:13:47
Hi, When I put a live pump on my 41 H in the 68 my local parts man told me the gears had never been changed from the first H through the last 350. It has had very hard use for all these years with many thousand hours. Use a 2001 loader with hyd bucket, also a reel type rock picker along with many other jobs, works well. I drilled and rethreaded one hole and made a small clamp for the other. Good luck, Chuck
CNKS
12-17-2006 14:05:26
Crankcase cover 6957DBX changed to 352168R21 at serial 344864, or about mid-late 1950. There is only one listing for the gear 6664DB, The D makes it part of the old number system, the newer system uses R. However the original gear would have said either D or DA, the DB could mean a heavier duty gear, someone else will have to answer that. But,parts that had extensive changes usually used the R system. You can go to www.caseih.com and look all this up, if you don't have the manuals.
Allan In NE
12-17-2006 03:07:19
Can't remember exactly, but the change came in '51 at serial number (about) 348xxx.
From that point on, it is a straight bolt on deal
Allan
tn terry t
12-17-2006 05:14:39
 Re: H Experts; Need Your Expertise in reply to Allan In NE, 12-17-2006 03:07:19
i dont know if someone had changed my 49 h or not but when i pulled it down to change the front cover to add the live pump low and behold there lived the same gear number that i had bought for a 300
CNKS
12-17-2006 14:12:58
 Re: H Experts; Need Your Expertise in reply to tn terry t, 12-17-2006 05:14:39
The H/Super H/300/350 all list the same number for the gear, but as I mentioned above, the gear in the early H's may have had an earlier suffix--wish someone could actually answer this, at least as regards the gear, as I might want to do this someday.
D Slater
12-17-2006 16:31:09
 Re: H Experts; Need Your Expertise in reply to CNKS, 12-17-2006 14:12:58
H front cover changed to same bolt pattern as pumps at engine # 344864 which in most cases is serial # of H tractor also. Cam gears started out with end in D , around 52 or 53 they went to DA then about time 300 series came out or little after they were out the gear went to DB. If a gear was replaced and sold by IH after DB came out thats what was sold to put in H on up. I don't know about heat treating or anything like that to improve gear by looking the only thing I ever noticed is later gears are thicker from hub out to gear teeth.
CNKS
12-17-2006 17:28:52
 Re: H Experts; Need Your Expertise in reply to D Slater, 12-17-2006 16:31:09
That's what I thought, just wasn't sure.
Allan In NE
12-17-2006 05:26:08
I sure don't know 'bout that gear. I'm just a cowboy dummy.
However, the front covers are different for sure. That top outside bolt is in a different location on the old ones vs the newer covers.
Allan
