International 424 loses oil pressure on gauge afte
Delbert Homebo
12-13-2006 15:34:59
I have an International 424 that has 2300 hrs and it loses oil pressure on the gauge, replaced idiot light with gauge. Seems to run Ok do not notice any difference in running but pressure dropd to 0, any ideas
El Toro
12-13-2006 16:16:04
 Re: International 424 loses oil pressure on gauge in reply to Delbert Homebo, 12-13-2006 15:34:59
I would check to make sure the oil gallery on the engine isn't clogged with sludge. Remove the gauge and connect a short piece of hose to where
the gauge was installed. Then have someone crank
over the engine and see if any oil is being dicharged from the hose. If you good oil flow I would find a calibrated gauge and install it to determine what the oil pressure is. If it still reads zero, I would drop the pan and check the oil pump. The relief valve on the pump me be stuck open. I wouldn't run the engine until you determine the problem. You could do major damage to your engine. It must have some pressure or you would have bearings knocking. Hal
