400 live pump, fit an H ?
arod
12-09-2006 18:09:18
Will the live pump from a 400 fit a farmall H?
randy hall
12-09-2006 19:26:05
 Re: 400 live pump, fit an H ? in reply to arod, 12-09-2006 18:09:18
the bolt pattern is a bit different on the pump mounting between an m and a 400. i could sell you the front cover from a 400 to put on your m so the 400 pump would bolt up.
Jim Ivens
12-10-2006 05:26:49
 Re: 400 live pump, fit an H ? in reply to randy hall, 12-09-2006 19:26:05
the late model M and the SM are the same as the 400 I don't know what the cut off year is, but I have a 52M it is interchangeable, or you could use a M&W pump they will fit both, holes are slotted
Wisconsin Cowman
12-09-2006 19:22:57
On a M I think it would work.
randy hall
12-09-2006 18:26:24
no
Randy as in Randy-IA
12-09-2006 18:41:56
 Re: 400 live pump, fit an H ? in reply to randy hall, 12-09-2006 18:26:24
What about on a M ?
Nat 2
12-10-2006 08:05:45
 Re: 400 live pump, fit an H ? in reply to Randy as in Randy-IA, 12-09-2006 18:41:56
Sometime in 1950, IH changed the front cover and timing gears on the Ms, so a factory live pump will work. Ms older than 1950 need to have the newer front cover and timing gear set installed.
