10-20 Manifold parts questions
Kevin LA-CA
11-18-2006 22:06:37
How many different manifolds were used on the 10-20. I have two tractors - one clearly is a distillate, the other has no heater box and appears to be gas only. Were there other versions? How did this affect the muffler situation?
Also, what pieces connect the carb to air cleaner? I am assuming a piece of pipe & two small rubber hoses. Both sets are missing.
thanks
kevin
Mike Androvich
11-19-2006 13:46:37
 Re: 10-20 Manifold parts questions in reply to Kevin LA-CA, 11-18-2006 22:06:37
There are basically three different version of manifolds if we are talking the farm tractor and not the industrial Model 20. First version was used from 1923 in to 1926. This version was a simple rectangular shaped manifold that had somewhat of a muffler that bolts to the manifold with 2 bolts and exits through a hole in the lower right hand section of the side panel. Changed in late 26, early 27 to a V-shaped manifold. A muffler made of thin sheet metal was mounted directly to the elbow of the manifold and was placed between the manifold and the fire wall. Exhaust went through the fire wall to cast iron elbow bolted to the firewall and out the side. Last version used no muffler but only a cast iron ninety. Exhaust exited out the corner of the side sheet via a notch. This manifold was able to switch heat settings via a baffle in the upper center and a valve on the end of the exhaust leg that could route more or less hot gas around the intake pipe. It was used until the end of production in 1940.
Nebraska Cowman
11-19-2006 00:43:13
All 10-20s were kerosene burning but aftermarket gas manafolds were available too. so it is pretty hard to tell what you have.
