fast hitch mower
Greg Derry
11-11-2006 09:50:16
I purchased a fast hitch mower for my 450. Where do I attach the lift chain and stabilizer chain? Thanks.
Jimmy King
11-11-2006 19:51:06
 Re: fast hitch mower in reply to Greg Derry, 11-11-2006 09:50:16
Hi Greg, I just went out and looked at my 460. On the left side there is a lug with a hole in it on the end of the rock shaft bracket the lift chane should have a clevis on it on the right side there is a cast tube and the stableizer chain should have a pin that will slip into it. That one keeps you from lowering it to low when you let the bar down. I have not ever had a mower for the 460, but we had one on a 230 would work the same way. The only difference was proably the size of the two point fingers.
