Farmall A transmission front oil seal
Sott Griffith
10-04-2006 18:23:32
I'm curious if anyone has tried and been succesfull in changing out the front oil seal on the input shaft of the transmission through the hand hole in the bottom of the tractor. Is it possible or will I have to split the tractor? I'm wondering if I can remove the shaft bolts and slide it out of the way far enough to remove the seal housing and replace the seal or have I gone off the deep end?
Thanks,
Scott
gene bender
10-05-2006 03:01:07
 Re: Farmall A transmission front oil seal in reply to Sott Griffith, 10-04-2006 18:23:32
split the tractor
doitall
10-05-2006 01:36:48
IMHO, you will have to split the tractor. Because the seal rides on the tranny input shaft coupler, there is a paper gasket which seals the coupler. Don't forget this simple gasket; it may leak otherwise. Hendrik
banjo
10-05-2006 00:31:34
Nope, gotta split the tractor.
Scott Griffith
10-05-2006 05:12:01
 Re: Farmall A transmission front oil seal in reply to banjo, 10-05-2006 00:31:34
Ok,
I"ll split it...
Charles McNelly III
10-05-2006 16:52:47
 Re: Farmall A transmission front oil seal in reply to Scott Griffith, 10-05-2006 05:12:01
When I replaced the front seal on my B, I took some 5/8" all thread about a 16" long and replaced the bolts with them. Sure made easy work of it. Good Luck.
Charles
