FIRING ORDER
KATHLEEN DARNEL
09-27-2006 15:39:07
FIRING ORDER ON A 1957 FARMALL 450 LP IF ANYONE HAS ONE IT WOULD GREATLT BE APRECIATED.
Wardner
09-27-2006 17:37:10
 Re: FIRING ORDER in reply to KATHLEEN DARNELL, 09-27-2006 15:39:07
All in-line four cylinder engines have the same firing order. I believe that also applies to V-4's and opposed fours. Don't know about X-4's. I think Henry Ford built some of those.
It has always amazed me that the foundries included the four cylinder firing order on their block castings. Every kid with an interest in engines knows about the four cylinder sequence.
Wardner
09-27-2006 18:17:18
 Re: FIRING ORDER in reply to Wardner, 09-27-2006 17:37:10
I am just rephasing something I read decades ago. Seeing as I had never seen the alternate order, I believed it was true. But I will take you at your word. I stand corrected.
El Toro
09-28-2006 14:26:14
 Re: FIRING ORDER in reply to Wardner, 09-27-2006 18:17:18
I gave you the wrong tractor. It waa an Allis
Chalmer model CA that has this firing order. 1-2-4-3. Hal
El Toro
09-28-2006 07:38:23
I think Case has used 1-4-3-2. Hal
Wardner
09-28-2006 17:04:40
 Re: FIRING ORDER in reply to El Toro, 09-28-2006 07:38:23
Two and three can never be consecutive. The same applies to one and four. I say "never" because it would add alot to the manufacturing costs of the crankshaft. It would also require five main bearings. Five main bearing cranks are the norm now but this wasn't the case a few years ago. Engines are now made to crank out more HP per cubic inch.
I am not really qualified to comment on this but I think there are harmonic balancing considerations when deviating from traditional firing orders. It would be interesting to look up the firing orders of engines that use gear driven balancers such as the Ford 172 cubic inch diesels.
El Toro
09-28-2006 17:27:46
 Re: FIRING ORDER in reply to Wardner, 09-28-2006 17:04:40
I've seen more 4 cylinder engine with the 1-3-4-2
firing order. The Allis Chalmer CA used the 1-2-4-3 firing order which is the reverse of what IH used on their 4 cylinder tractors. Hal
Bob
09-27-2006 17:46:52
Wardner,
You posted "All in-line four cylinder engines have the same firing order."
That's NOT true.
Both 1-3-4-2 and 1-2-4-3 are common 4-cylinder firing orders.
The difference is in how the cam lobes are set up.
Yugrotcart
09-27-2006 16:04:35
1-3-4-2
#1 being at the rad end of the engine.
KATHLEEN DARNELL
09-27-2006 16:08:41
 Re: FIRING ORDER in reply to Yugrotcart, 09-27-2006 16:04:35
WHAT IS RAD?
Jossette
09-27-2006 18:30:28
 Re: FIRING ORDER in reply to KATHLEEN DARNELL, 09-27-2006 16:08:41
if any doubt. It will be stamped on the engine above the distributor. #1 will be towards the front and #4 will be towards the seat.
jon priebe
09-27-2006 16:14:30
rad is short for radiator
brainerd dave
09-27-2006 22:40:26
 Re: FIRING ORDER in reply to jon priebe, 09-27-2006 16:14:30
Jon, you & I have the same last name. You don't see it every day.
Dave Priebe
Yugrotcart
09-27-2006 16:14:17
Radiator
kfox
09-27-2006 18:29:46
 Re: FIRING ORDER in reply to Yugrotcart, 09-27-2006 16:14:17
The firing order is 1-3-4-2, but the cylinders are numbered 1-2-3-4 from the front of the engine to the back. (I just explained this to someone this afternoon.) ken
