H Carb Rebuild Tips?
neblinc
08-28-2006 11:10:52
I orderd my rebuild kit from Case IH and wanted to know if there are things I should look out for when I rebuild the carb on this H.
Randy
neblinc
08-29-2006 05:12:27
 Re: H Carb Rebuild Tips? in reply to neblinc, 08-28-2006 11:10:52
Thanks for the tips!
I am surprised that the bushing does not come with the kit for that price : (
Randy
John in Ct
08-28-2006 13:27:06
Replace then ream the throttle shaft bushing. It does't come in the IH kit but can be obtained from IH.
old
08-28-2006 11:29:25
One thing to look for/at is the float and make sure it has no dents, isn't bent and the 2 floats sit even with each other. You also need a can of good carb cleaner something like beemans etc and soak the carb for 24 or so hours and then blow it out and also use some spray carb cleaner to make sure all passages are open and free of dirt/rust. Also another good thing to do is use a small wire or as I do a tourch tip cleaner to clean out the small passages in the carb. When you put it back on you may have to adjust the govanor to match the carb again and be careful to get the gov. to carb lined up right, or you will have problems
kfox
08-28-2006 17:50:12
 Re: H Carb Rebuild Tips? in reply to old, 08-28-2006 11:29:25
Be careful with the idle jet. Its the small brass tube about 3/4" long, and it screws down in the top side of the bottom half. The screwdriver slot likes to break off. Sometimes they are missing, or all ready broken. If thats the case you can drill them out with a 6-32 tap drill and re-thread the hole. good luck ken
