Order Farmall Cub Parts Online
'53 Cub steering shaft woodruff key
Lane R
08-12-2006 16:09:32
Does anyone have any idea how to remove a woodruff key in the lower portion of the vertical steering shaft that runs between the steering gear and the steering arm. We are not sure if it is stuck but it will not come out when tapped on with a brass drift.
Brownie 45
08-13-2006 08:58:13
 Re: '53 Cub steering shaft woodruff key in reply to Lane R, 08-12-2006 16:09:32
Is there room to get a chisel in? You'll probably need a new key anyway, so see if the chisel & a 3 lb. hammer won't bump it loose.
john *.?-!.* cub owner
08-12-2006 19:22:48
I never had toruble with that one, but did have a woodruff key that was stuck so bad a machine shop finally welded a nut to it so he coulg get a grip on it.
