123 rebuild ?
R Fink
08-08-2006 10:44:42
rebuilt 123 for a super c finished it last winter ,am installing now.I dismantled oil pump to check over looked ok installed on engine pumped in breakin oil through the pressure gauge port . now i have it installed and have cranked the engine over for a good amount of time and do not have pres. yet. do these pumps need to be primed???? or what.
Stan(VA).
08-08-2006 19:24:05
 Re: 123 rebuild ? in reply to R Fink, 08-08-2006 10:44:42
I've also had good results by saving the oil filter for last. When re-filling the crankcase, put the last quart of oil directly in where the oil filter goes (large and small holes), just before starting the engine.
Stan(VA).
K.B.-826
08-08-2006 16:54:08
Sure your guage is good? Get a 100 psi hyd. pressure guage from your local auto parts or hyd. shop. Install directly into the oil gallery. Start the engine, shut it down if oil pressure does not come up within five seconds. I always pack oil pumps full of assembly grease, always works.
El Toro
08-08-2006 15:41:52
You should've primed the pump. You may need to drop the pan and set it in a pan of clean oil to be on the safe side. Make sure you have working a oil pressure gauge. I would still pump that oil into the oil gallery. You should have the gauge installed in a pipe tee so you can shutoff the oil gallery feed. The pressure should be ok then. Hal
John M
08-08-2006 14:09:40
How are you determining that you dont have pressure? Ive never had a gauge register when turning over theengine with the starter, but cpome up as soon as its running.
Randy S.E.-MN
08-08-2006 13:05:24
Sometimes if you let it (the pump) sit overnight submerged in oil (in the pan or otherwise) the oil does migrate to where it needs to be to prime itself, if this is your problem...Randy
Bob
08-08-2006 11:03:59
Packing the gears with petroleum jelly (Vaseline)
helps them prime quickly.
Where you're at now, you can try filling the crankcase WAY overfull of oil, cranking it until the pump primes, then drain out the excess oil BEFORE trying to start it.
Bob
08-08-2006 11:03:56
Bob
08-08-2006 11:03:53
Bob
08-08-2006 11:05:32
 STUPID 'puter.... in reply to Bob, 08-08-2006 11:03:53
Sorry, I'm on a different 'puter than usual, and having trouble with it "multiple posting".
old
08-08-2006 11:50:44
 Re: STUPID 'puter.... in reply to Bob, 08-08-2006 11:05:32
Bob looks like you have a stuter problem LOL
