Order Farmall Cub Parts Online
52 Cub stuck in 3rd
knbshn
08-07-2006 16:55:32
Thanks for the replies, another question - Is this Cub supposed to have a spring loaded shifter lever? someone took the knob off the lever, welded an extension on it to make it taller, BUT it also has a spring at the base of the shift lever so as to (I"m guessing here) keep the shifter lever end (beneath the cover) up out of the shifter forks. Is this the way it should be?!!
john *.?-!.* cub owner
08-07-2006 19:17:02
 Re: 52 Cub stuck in 3rd in reply to knbshn, 08-07-2006 16:55:32
try the link below, or if it doesn't work, copy and paste thsi into your browser.
Link
Nat 2
08-07-2006 17:02:28
The spring is correct.
The extension, obviously, is not. Somebody did the exact same thing to mine. It's supposed to have the short bent shifter, but it's got a long "Rat Fink" style shifer lever that bangs me in the left shin while I'm mowing. A most annoying feature that will be remedied with a hack saw come this winter.
