826 Brakes, Rtight Inop
Jim Allen
08-04-2006 18:28:23
Between about two months ago and now, it seems the right brake on my 826 has gone inop. Started my chisel plowing today, stabbed the brake for a turn and no action. The left works fine. Darn little in the manual on this, but after looking, I guess I can try bleeding it tomorrow. My 826 has the difflock, so that appears to complicate that right assemby. Any other tricks to try or am I facing a brake job.My manual also des not cover the diff lock. How much does that complicate a brake job. As always, gents, thanks in advance. Jim
the tractor vet
08-04-2006 20:30:04
 Re: 826 Brakes, Rtight Inop in reply to Jim Allen, 08-04-2006 18:28:23
The Diff. lock is just a few more pices and parts to remove before ya get to the drum and it is not a big deal there . What has probably happened is that the splin part of the disk broke off the disks . I would recomend that you get a seal kit and install a new pinion seal and replace the two big O/Rings on the piston and reset the self adjuster and clean up the drum and free up the return springs , if you find any return springs weak or broken replace all with new ones.
