Cheep tricks
Baxter
07-12-2006 17:38:52
Are there and cheep trick that you guys know of just little things for getting the most out of an M want to use it for pulling and just wanted to get some tips that would get a little more power to the ground
in-a-bind
07-13-2006 00:12:47
 Re: Cheep tricks in reply to Baxter, 07-12-2006 17:38:52
There are no CHEAP TRICKS when you are pulling.
Everyone does things a little different.
Everybody CHEATS some way or the other with the so called STOCK tractors.
If you are new to the pulling circut you better get ready to spend some money if you expect to compete with the others that have been at it for a while.
Before going too crazy, the first thing that you should do is ckeck to make sure that you are within the rules (if any apply), in case someone checks out your tractor, and the judges decide that they will NOT let you pull against their regular or favorite pullers.
