400 low hydraulic pressure
Tom New Jersey
06-29-2006 09:29:06
My farmall 400 has about #500 hyd pressure,I checked the regulator valve, safety valve, replacing the safety valve spring which was 3/8" too short. No change, has anyone had the same problem?
Tom New Jersey
06-30-2006 04:56:41
 Re: 400 low hydraulic pressure in reply to Tom New Jersey, 06-29-2006 09:29:06
I should have also said that I found the screen on the intake plugged, collapsed, and with a hole in it (replaced), also the screen and orifice for the regulator valve were in excellent condition.
Jimer
06-29-2006 20:08:24
If it turns out to be the pump, I have a new one that has been used about 15 mins. I paid $510 and will entertain any reasonable offer. My problem turned out not to be the pump, but the seat in the safety valve block.
jossette
06-29-2006 17:11:25
I would check to see if there is enough oil in the tank, check to see if there is any air getting into the system and change the resevoir filter and regulator screen before you go buy a pump.
old
06-29-2006 10:31:52
Yep see it/here it all the time. Your pump porbably has wornen out and need to be replaced. What happens is the gears sort of cut in to the plates and that causes it to loose preassure. Bad thing it the cost of replaceing the pump. I have a friend that has the same problem with his 450, Case/IH wants something like $1200 for a new one and a rebuilt one from on line companys are around $600
