Rod and Main Bearings markings.
Tom Windsor
06-23-2006 18:12:38
"I thought" that one could look on the back side of the rod and main bearings and see if they are standard, 10 over or 20 over, so I looked and found the following text and numbers on 4 lines:
"c IH (the logo) 002
7 6 F 23
355268-R1
Made in USA"
Does anyone have any insight into how to interpret this? Standard?
Tom Windsor
El Toro
06-24-2006 03:44:40
 Re: Rod and Main Bearings markings. in reply to Tom Windsor, 06-23-2006 18:12:38
I used .002" undersize bearings on a Farmall A. The crankshaft only needed to be polished. You should have that shaft measured at your local auto machine shop. I think .003" undersize bearings are available too. If your shaft is worn beyond these limits they may need to grind your shaft to .010" undersize and these bearings are available too. Hal
JJK
06-23-2006 21:29:05
The 76 should stand for the year 1976 when the bearing was made so sometime around 1976 they were rolled in if that interests you.
randy hall
06-23-2006 18:29:50
your bearings are two thousands of an inch undersize for use on a slightly worn crankshaft.
06-23-2006 18:52:06
 Re: Rod and Main Bearings markings. in reply to randy hall, 06-23-2006 18:29:50
Forgive me for not understanding...exactly...but again "I thought" that you could only get these bearings in increments of 10 thousants and not understanding how someone could find 2 thousants???
TW
kfox
06-23-2006 18:59:56
 Re: Rod and Main Bearings markings. in reply to [email protected], 06-23-2006 18:52:06
Tom,
The H I'm working on also had .002 main & rod bearings. It probably only had one bearing replacement during it's working life. I had to have the crank turned to .010 undersize when I rebuilt it. ken
