Thrust Bearing on bolster/400
SDE
06-07-2006 03:41:58
I think this bearing was quite expensive when I replaced it on my other tractor. Is it going to cost about the same everywhere I go, or should I shop around? What else should I expect to replace while it is apart? The steering is so stiff that even in 5th gear it is tough to control or move the steering wheel. It wasn't that bad the first time I got her going this spring, so something is just not right anymore.
Bob M
06-07-2006 09:11:26
 Re: Thrust Bearing on bolster/400 in reply to SDE, 06-07-2006 03:41:58
First thing I'd do is disassemble the front end and make sure it's really the thrust bearing that's the problem.
My Super H had similar steering difficulties when I got it. Upon taking it apart I discovered someone before me had left out a spacer below the thrust bearing during a previous reassembly. The stiff steering was caused by the flange on the pivot shaft rubbing on the undeside of the fixed bolster. (The thrust bearing however was found to be in "like new" condition.) Punch below for a few photos taken during the repair.
However if the problem IS a bad thrust bearing, take the number off it then call your local bearing supply house. In all likelihood a new one will be cheaper there than at the CIH dealer.
Also while you've got it apart suggest checking the pivot shaft bushings and replacing them if they are worn!
SDE
06-07-2006 14:31:33
 Re: Thrust Bearing on bolster/400 in reply to Bob M, 06-07-2006 09:11:26
Thank you very much for the excellent photos and detailed discriptions. I think I may know where the problem is located. If I am lucky it will be the bolts that are holding the wide front, center steering arm/plate to the bolster. Your response was exactly why I placed this question.
Thank you once again. SDE
