help with my super a
c shep
05-20-2006 20:12:33
i have a super a that started and ran great,untill i replaced some wiring on the ignition sw. and the ampmeter. now,it will not start at all.i have traced the wiring as best that i can,no help.i got something in the wrong place or,left a wire off.the system has been converted to 12 v.with an alternator.please advise me if you can help with the correct wiring . thanks for any help in this matter. charles
Marty Johns
05-21-2006 18:42:32
 Re: help with my super a in reply to c shep, 05-20-2006 20:12:33
Wiring-run your serial # and then ask BOB M for his web page! you can wire it correctly very easily!!!!! !!!!!
Brownie 45
05-21-2006 05:37:07
You should have 12 volts at the ammeter, then a wire to the ignition switch, 12 volts there also, then a wire to the coil[ or possibly a resistor ahead of the coil - dropping 12 to 6 volts] also 12 volts there. If you don't have voltage at any of these points, check why the voltage isn't getting through.
Dave BN
05-20-2006 21:27:13
Not real familiar with Super A, but offhand I'd say you are missing battery voltage toyour coil. Do you have a volt meter? If so, check the voltage to the coil. It should be 12V. Dave.
