Model 2400 with D179
Anthony Thayer
04-26-2006 11:34:38
I am having problems with the engine not running right at high rpms and it smokes at Idle. I just rebuilt the engine and I need help understanding why it is doing this. If you bring the rpms up it will misfire and black smoke will pour out. I would also like to remove the injectors but I don"t know how. Any know how to do this? Also any one have the pages of the manual that talks about the injectors? Any help would be great as I am ready to do spring cleaning with this tractor. Also the engine seems to loose it prime if it sits for along time. I have checked fitting and tightened any I could find. Help Help
Bernard le mécano
04-29-2006 17:23:50
 Re: Model 2400 with D179 in reply to Anthony Thayer, 04-26-2006 11:34:38
Hi, does the air filter is OK. Be sure the timings marks inside the timing cover are OK. To remove the injector, remove the return line, pressure line, clamp and pull on the injector. Bernard le mécano Québec Canada
El Toro
04-26-2006 15:03:24
Those injectors probably are due for a rebuild and the pump may need it too. You must have leakage to cause your engine to loose its prime.
May be an injector. Hal
