farmall-H
dave loughmille
04-19-2006 10:43:11
just bought this 1947 beauty and don't know what kind of gas i can put in it. Is reg. no lead ok?
sammy the RED
04-19-2006 20:12:47
 Re: farmall-H in reply to dave loughmiller, 04-19-2006 10:43:11
You can use 87 octane with no problems.
CNKS
04-19-2006 13:00:05
Yes, no need for any higher octane unless someone has increased the compression drastically. As long as you don't get detonation under heavy load, you are ok. Compression is only 5 or 6 to 1.
old
04-19-2006 12:23:03
It will run just fine on the cheap stuff. Oh wait I forgot there is no longer any of the cheap stuff so I guess I should say the cheapest stuff you can buy it will run on ok unless its half water.
dig
04-19-2006 11:17:26
That's what I've used in mine for the last 15 years with no problems.
williamf
04-19-2006 11:06:37
Yes. Even if it was originally a kerosene or distillate model, yes.
Wm
