grounded out the generator for charging
lekander883
04-08-2006 06:46:12
Wasnt getting the most out of my charging system on my farmall H so started playing with the generator a little. After grounding out one of the terminals on the generator I noticed the amp meter shot up close to 18 volts. Ive heard of some people doing this as long as you dont run your tractor real long. I thought of putting a switch to ground so I could turn it on and off for awhile while in use. Any thoughts before doing this.
Hermit
04-08-2006 19:07:47
 Re: grounded out the generator for charging in reply to lekander883, 04-08-2006 06:46:12
If you have a 3 brush generator, you can adjust the 3rd brush to increase amp output. A whole lot safer than running full generator output with a switch.
Bob
04-08-2006 13:10:36
Guys used to use big old war-surplus rheostats, so the charging rate could be set where desired.
John T
04-08-2006 07:34:02
rek, I have to agree with Allan. If you dead ground the gennys Field post that allows max charge condition which is fine if used ONLY for enough time to fully charge the battery. HOWEVER over charging n out gassing n boiling over a battery is harder on it then undercharging, and once shes charged the rate ought to back off.
A) Does the tractor have a full fleged 3 terminal (BAT GEN FLD) Voltage Regulator or the simple 2 wire (BAT GEN) Cutout Relay and the light switch field current control ???? (see below)
1) VR SYSTEM: One thing you may wanna try regardless is to insure the VR (if thats what it has) has a good bond/connection to frame ground/gennys case cuz if none exists or its corroded or resistive, even a good working VR cant do its job!!! Run a good jumper wire from the VR's metal base to a good frame ground n see if she works okay then???? If so repair that n do away with your cheat ground method.
2) CR SYSTEM: If it has the simple 2 wire (BAT GEN) Cutout Relay and uses the light switch field current control method and she dont charge, the light switch may be bad or its resistor is bad or it doesnt have a good to dash bond/connection or the wires open from the gennys Field post up to the light switch !!!!! !!!!! If the switch is good and it has a good to dash ground, thats where the gennys Field post gets it return current path for it to charge, the same thing that happens when you provide that cheat ground at the gennys Field post. I would trace the wire from the gennys Field post up to and through the switch and insure the switch has a good ground if its the 2 wire CR system that uses the light switch to troubleshoot that circuit !!!!
From what you told us it seems your genny (the more expensive component) is fine so if alllll l connections are good and the wires good from the gennys Field to the switch and the grounding (light switch or VR) isnt the problem, Id be investing in a new VR or light switch as needed.
John T in Indiana
Nebraska Cowman
04-08-2006 06:56:37
yup, beats trying to keep a darn fool regulater working.
Allan In NE
04-08-2006 06:51:37
By doing that, you are bypassing the regulator and telling it to charge full bore.
I'd be fer checking or replacing that regulator.
Allan
