Antifreeze Leak at Fan
RandyMcC
04-01-2006 19:31:45
I have antifreeze leaking at the front of the fan on my H. Do I have to remove the radiator to replace the fan shaft packing?
Steven@AZ
04-02-2006 07:03:39
 Re: Antifreeze Leak at Fan in reply to RandyMcC, 04-01-2006 19:31:45
I believe you can just tighten the packing nut a little bit as well. Mine leaked when I put it together (sitting 20 years dry didn't help things) so I tightened the nut. Now when it drips I know it's time to give it a shot of grease, then it stops.
Or take it all apart and put in new packing.
Marv
04-01-2006 19:48:50
Yes the radiator will have to be removed. I recommend you remove all the old packing before installing the new packing. Approx. 5 to 6 rounds of packing should be sufficient.
