farmall m
anyone
03-29-2006 17:01:18
Can anyone tell me about the hyd lift on a 1949 farmall m? Does it work off the 90 weight oil in the rear end, or does it have its own hyd oil that it uses. If it has its own where do you check and fill the hyd system? It has two cylenders one on each side and they are connected with hoses to the middle and side of the tractor under the side grain pulley.
farmallhal
03-29-2006 18:11:24
 Re: farmall m in reply to anyone, 03-29-2006 17:01:18
Use 30 wt. non-detergent oil as a detergent oil will foam. It holds about 6 quarts if drained before filling.
TractorFan1
03-29-2006 17:33:56
The M "Lift All" pump is build inside a cast reservoir, and uses 30# oil. The filler neck is on same side and just ahead of the belt pulley.
