230 fast hitch problems
rodowen
03-25-2006 07:42:04
I was using the 230 to blad the drive, when the Anti-Sway pin broke. Upon further review.....it has been spot welded before. Can I get a replacement? or d I become a fabricator again?
Thanks
farmallal
03-25-2006 12:30:42
 Re: 230 fast hitch problems in reply to rodowen, 03-25-2006 07:42:04
I don't know if the same pin is common to the Super C and 200 model tractors or not since I don't see anything identified as an anti-sway pin in my SC parts catalog. CaseIH might have them as I've found they had some pins for my SC fast hitch. David Cripps in Tennessee might be able to help you as he was parting out a half dozen SC and 200 fast hitches recently. His email is: dagecr@dtccom.net if you want to contact him. Would be nice to have a part no. available if you have access to a parts catalog. Hope this helps. Hal
rodowen
03-26-2006 06:17:19
 Re: 230 fast hitch problems in reply to farmallal, 03-25-2006 12:30:42
I did get the part number from the local dealer. Sorry I forgot to put it down.
The number is: 522912R21
They call it the lateral shaft fr Swing assembly.
It is now a retired part and no longer available from IH/Case
Thanks.
farmallhal
03-26-2006 06:43:10
 Re: 230 fast hitch problems in reply to rodowen, 03-26-2006 06:17:19
This part no. is not listed in my Super C parts catalog. It could have been a later no. which replaces the earlier item on a Super C. I would still suggest you contact Mr. Cripps as he has a lot of stuff from fast hitches and that size of tractor. Other then that just keep looking and do the salvage yard hunting and they might have a hitch assembly they are selling parts off of. Good luck in finding your part.
farmallhal
03-26-2006 06:35:11
