installing fuel bowl assembly on a gasser
Tom F
03-24-2006 14:46:34
My little A has been leaking fuel at the shut off valve. I aquired a new fuel bowl assembly and was wondering if anyone could tell me what kind of thread sealant I need to connect it to the tank. MANY THANKS
Kelly C
03-24-2006 20:05:10
 Re: installing fuel bowl assembly on a gasser in reply to Tom F, 03-24-2006 14:46:34
I just did that today on my 706. White tape on the threads. I purchsed a hose connector nipple from NAPA. This screws into the bowl and allows you to use standard fuel line hose.
Use tube cutter and cut out the old fuel line any where you want before the carb. Add fuel line and 2 hose clamps and you done. Easy on and off the next time. No more cracking the fittings so they leak.
Dellbertt
03-24-2006 15:26:18
Tom, if the fuel bowl assembly did not come with a screen in the top make sure to buy one for it.
They are available most anywhere including TSC.
Dell
El Toro
03-24-2006 15:14:21
I would use Gasoila "soft set". I use on it natural gas pipe lines and any pipe fittings used with the different fuels. Hal
www.federalprocess.com
Dave BN
03-24-2006 14:58:21
I use the same teflon stuff I use in my plumbing projects. I use steel brake line from NAPA from the sediment bowl to the carburetor. It's kinda hard to bend but the end result is great and it's cheap. Dave.
Tom F
03-24-2006 15:10:58
 Re: installing fuel bowl assembly on a gasser in reply to Dave BN, 03-24-2006 14:58:21
Thanks Dave
