Super A,Need help please
Tim in Va
03-23-2006 17:54:02
Just bought a Super A not sure of year, but could someone please tell me what fluids to use for the hydraulics and trans. Thanks for any help.
VAJerry
03-24-2006 06:46:34
 Re: Super A,Need help please in reply to Tim in Va, 03-23-2006 17:54:02
What part of Va are you in?
Tim in Va
03-24-2006 16:24:44
 Re: Super A,Need help please in reply to VAJerry , 03-24-2006 06:46:34
VAJerry...Ilive in central VA,Amelia county.
Hugh MacKay
03-23-2006 22:46:31
Tim: Your in good hands with Haas, I didn't even read what he said, don't have to, plus I know I can't improve on it.
banjo
03-23-2006 20:22:54
the old manuals don't say anything about the current fluids.thats why we come here to get current info. congrats on the super a i own 2 of them .
Haas
03-23-2006 19:48:17
Get a manual!!! Use 90w gear oil in the transmission and final drives. Don't forget the final drives, they are separate from the transmission. Level plugs for the final drives (also serve as fill ports) are located at the front of the final drives between the front lower drawbar attachment holes. Socket type plug takes a 1/2 inch drive. The final drives hold 3 pints each. Level plug for the transmission is behind the brake actuator rod on the left front of the transmission. You have to take the pin out of the brake clevis to get at it. The transmission holds 5 quarts. Maybe closer to 6 if you have the PTO and belt pulley. Use Hytran tractor fluid or equivalent in the hydraulic system. Fill to the bottom of the fill port. When filling, make sure the rockshafts are in the rear position, as that is when the cylinders are retracted and the most fluid is in the reservoir. Also use caution when you remove the fill plug, as there is no vent on the reservoir and pressure tends to build up in the thing and can blow out fluid when you remove the plug. Get a manual!!
Tim in Va
03-24-2006 16:22:47
 Re: Super A,Need help please in reply to Haas, 03-23-2006 19:48:17
Haas..When you say Hytran,do you mean the same hydraulic/trans fluid like used in ford 8N? Thanks For the help.
haas
03-24-2006 19:10:01
 Re: Super A,Need help please in reply to Tim in Va, 03-24-2006 16:22:47
Hytran is the IH version of tractor fluid that is used in most all modern tractors as combination hydraulic fluid and transmission lubricant. Most any all purpose "tractor fluid" will work. Around here, they even have that a Walmart, but any farm tractor dealer will have something that will work.
Tim in Va
03-25-2006 04:22:04
 Re: Super A,Need help please in reply to haas, 03-24-2006 19:10:01
Haas....Thank you,I understand what youre talking about. I was really unclear on this because the I&T book said touch control hydraulic or something like that and i knew there had to be something that could be used in its place. Anyway thanks again for the help.
