140 Conversion kit
Gerald Hochberg
03-12-2006 07:37:47
I have a older IHC 140, 6 volt poss.ground, By installing a 12 volt conversion kit. Would the 12 volt be neg. ground? THANKS. JERRY HOCHBERG.
El Toro
03-12-2006 08:33:06
 Re: 140 Conversion kit in reply to Gerald Hochberg, 03-12-2006 07:37:47
You will need to install a ballast resistor between the ignition switch and 6 volt coil when
changing to 12 volts or use a 12 volt coil. The small negative terminal on the coil will now feed your distributor since you're going with a negative ground on the battery. Hal
gene bender
03-12-2006 08:04:19
The ground is determined by what you use for the 12v gen system as there are 12v generators that look like the original 6v ones. Their ground will be determined by the reg that would be used with them. Most alts will be neg ground.If you want the tractor to appear original then go with a 12v gen and correct regulator. The regulator will be marked for which ground is needed.Either pos or neg
ryan from WI
03-12-2006 07:41:32
Yes it is a neg ground.
