Leaking 330u
Tweeter
02-24-2006 14:56:45
I drained the transmission today in my 330u. I put about 4 gallons of Kerosene in and drove it around awhile. I drained that out for the better part of the day and when there was no more drips I filled with 7gal Hy Trans. While I was under the tractor I found two factory drilled holes in clutch housing on the bottom side under the battery and right behind the inspection plate on the underside. There is one on each side of the tractor. They are inline with the middle drain plug. The one was full of dirt. I cleaned them both and now they are slowly dripping oil/water mix. There is fluid dripping from what I think is another inspection plate right behind where the front axle assembly bolts to clutch housing with three bolts. Is that tranny or engine?
Gene Brooks
02-24-2006 16:11:38
 Re: Leaking 330u in reply to Tweeter, 02-24-2006 14:56:45
the holes are called weep holes ; leaks indicate leaks in the trans and the t/a seals and i think that thier there to keep condensation from building up I have them on my 350 utility Gene
CHRISCO
02-24-2006 15:10:11
I HAVE A 340U AND THE FRONT PLUG WAS FOR THE TA INSPECTION FROM THE BOTTOM AND I BACK PLUGS WERE FOR OIL LEVALS BUT IF THIS 330 SIT OUT SIDE FOR ALONG TIME THEN IT TAKES ALONE TIME TO GET THE WATER OUT
