330U...Hydraulic System Not Working
Tweeter
02-16-2006 08:58:15
The hydraulic system on my 330U is not working properly. It will work only sometimes and when it does it works fine. I have an inkling that there might be water in the system that is freezing (maybe) because it has been pretty cold out here. Do I have to use Hy-Trans if I change the fluid or is there something else i could use that might be cheaper. I plan on doing more hydraulic maintenance to it this spring so i would replace the fluid with Hy-Trans then. What hydraulic fluid could I use for the time being?
PAULIH300
02-16-2006 09:18:59
 Re: 330U...Hydraulic System Not Working in reply to Tweeter, 02-16-2006 08:58:15
At least use a premium tractor/hydraulic fluid,not the usual cheap AW32,R&O,Log splitter oil.
Tweeter
02-16-2006 09:24:00
 Re: 330U...Hydraulic System Not Working in reply to PAULIH300, 02-16-2006 09:18:59
How about the tractor hydraulic fluid that sells at a Tractor Supply Company store?
Nat 2
02-17-2006 04:59:53
 Re: 330U...Hydraulic System Not Working in reply to Tweeter, 02-16-2006 09:24:00
Read the label on the fluid. If it says anything about meeting Hytran specifications, then it's okay.
Beware of the yak urine that some try to pass off as hydraulic fluid.
PAULIH300
02-16-2006 14:25:51
Dont have one of those around here,but most any premium "tractor/Hydraulic" meets IH HyTran specs.
