Order Farmall Cub Parts Online
international cub
Irvin Harris
02-11-2006 08:25:54
Tractor starts and runs with choke out. with choke in engine dies. need advise.
R-cubed
02-11-2006 14:09:31
 Re: international cub in reply to Irvin Harris, 02-11-2006 08:25:54
My Cub does that until it warms up. You need to take the choke off a little at a time until it is warm this time of year. That could take 3 or 4 minutes to warm up enough to take the choke off in cold weather. If it dies then it's time to check the fuel line/filter etc.
Ram4wd
02-11-2006 12:29:24
Disconnect the fuel line to the carb and check the flow. line could be clogged some.
Farmall Ed
02-11-2006 12:05:13
Take the air intake pipe off and check the position of the choke plate in relation to your lever setting. Ed
Bus Driver
02-11-2006 10:37:35
My first step would be to clean the high speed jet. It is the brass 3/8" hex on the side of the carburetor. Clean the small hole in the center of the end of the jet. Do not alter the hole size in any way. A 10 minute job. The high speed jet is not adjustable on the CUB.
old
02-11-2006 08:49:44
Check you fuel flow from the tank, may have a clogged fuel line, if thats good you probably need to rebuild the carb.
Bob
02-11-2006 08:47:34
Adjust the carburetor, if that doesn't help, completely disassemble it, and properly clean it.
