d436 temp sending unit
D Sellers
02-05-2006 17:04:48
Gentlemen, just got a 986, all gauges work except temp gauge, it is failed low, where is the temperature sending unit located on the d436 engine?
thanks
DSellers
IaGary
02-05-2006 20:20:47
 Re: d436 temp sending unit in reply to D Sellers, 02-05-2006 17:04:48
DSellers those wire connections like to corrode on the sending unit so try cleaning the connections to see if that will fix it. I've had to do it several times.
IH GARY
02-05-2006 18:33:36
Sending unit is on the right side of the cylinder head in front of the exhaust manifold. It"s hid behind the bracket that holds the water filter
